ww111
Junior Member | Редактировать | Профиль | Сообщение | Цитировать | Сообщить модератору WinBuilder [082] - Project log dated from 14.06.2014 Scripts Processing section: [_Add] В файл: [WimBoot] 0.150 seconds Errors (Processing section: [_Add] В файл: [WimBoot]) FileCopy - Failed to copy [%BaseDir%\ISO\HddBoot\I586\BootDI.wim] to: [%BaseDir%\ISO\MultiBoot\1.wim]: Системе не удается найти указанный путь. %BaseDir% = D:\RusLiveGenaMini\ (WinBuilder's path is replaced by the variable %BaseDir% to make the log easier to read) WinBuilder Version [082] Variables %_ML_B_Depend% %_ML_RegAddBootMethod%ExpEnvVar %_ML_RF_TYPE%1 %_ML_Shortcut_TYPE%1 %API%%BaseDir%\Projects\RusLiveGena\Basic\Build\Macro_Library.script %API_TYPE%1 %APIDEF%MacroLibrary %APISUBDEF%Add_Shortcut,Add_DesktopIni,Add_Url,*Add_Pin,Arch,Call,ScriptInterface,Others,Registry,Require,RunFrom,Unpack,Variable %APIVAR%ApiVar %AppMode%wbaNormal %BaseDir%D:\RusLiveGenaMini %Build%2011-Aug-06 15:21 %Comp80%false %Day%14 %FileVersion%82.0.1.0 %GlobalSupport%%BaseDir%\Workbench %GlobalTemp%%BaseDir%\Temp %GlobalTemplates%%BaseDir%\Workbench\Common %HostOS%XP %IsoDir%%baseDir%\ISO %IsoFile%E:\RusLiveGenaMini_2013_07_26\ISO\RusLive_WIM.ISO %IsoFileName%RusLive.iso %Month%6 %OSFamily%NT5 %PE_Programs%%SystemDrive%\Program Files %PluginArch% %PostISOScript%%BaseDir%\Workbench\Gena\UserData\ISO-PostProcess.Script.txt %PreISOScript%%BaseDir%\Workbench\Gena\UserData\ISO-PreProcess.Script.txt %ProcessorType%586 %ProgramFilesDir%C:\Program Files %Programs64%C:\Program Files %ProjectCache%%BaseDir%\Workbench\Gena\Cache %ProjectDir%%BaseDir%\Projects\RusLiveGena %ProjectInfo%%BaseDir%\Workbench\Gena\UserData\ProjectInfo.ini %ProjectName%Gena %ProjectSupport%%BaseDir%\Workbench\Gena %ProjectTemp%%BaseDir%\Temp\Gena %ProjectTemplates%%BaseDir%\Workbench\Gena\UserData %ProjectTitle%Gena %RAM_exclude%bootsect.bin|BOOT.DRIVE| %RegDefault%E:\RusLiveGenaMini_2013_07_26\Target\Gena\I386\System32\config\default %RegSoftware%E:\RusLiveGenaMini_2013_07_26\Target\Gena\I386\System32\config\software %RegSystem%E:\RusLiveGenaMini_2013_07_26\Target\Gena\I386\System32\SETUPREG.HIV %SettingsDrive%#$pSystemDrive#$p %ShortcutCMD%LNK-Buildtime-Explorer-FreeShc.exe-NoDebug %ShortcutDecisionScript%E:\RusLiveGenaMini_2013_07_26\Projects\RusLiveGena\Basic\6 ShortcutsCentro.script %ShortcutScript%E:\RusLiveGenaMini_2013_07_26\Projects\RusLiveGena\Basic\6 ShortcutsCentro.script %source_sys%H:\XpSp3Ru\I386 %source_win%H:\XpSp3Ru\I386 %SourceArch%x86 %SourceDir%D:\project %Target_prog%%baseDir%\Target\Gena\Program Files %target_sys%E:\RusLiveGenaMini_2013_07_26\Target\Gena\I386\System32 %target_win%E:\RusLiveGenaMini_2013_07_26\Target\Gena\I386 %TargetDir%%baseDir%\Target\Gena %TargetProfilesBaseDir%%BaseDir%\Workbench\Gena\UserData\TargetProfiles %TargetProfilesUserDir%E:\RusLiveGenaMini_2013_07_26\Workbench\Gena\UserData\TargetProfiles\Users\Default User %TargetWOW64%x86 %TempDir%C:\DOCUME~1\Admin\LOCALS~1\Temp %TempFolder%%BaseDir%\Temp\Gena %Tools%%BaseDir%\Projects\Tools\Gena %UserName%Admin %UserProfile%C:\Documents and Settings\Admin %Version%082 %WBexe%%BaseDir%\WinBuilder82.exe %WindowsDir%C:\WINDOWS %WindowsSystemDir%C:\WINDOWS\system32 %Wow64%False %Wow64Dir% %Year%2014 Processing section: [_Add] В файл: [WimBoot] File [%BaseDir%\Projects\RusLive\Finish\2 Create Image\WimBoot.script] Версия [75] IF - File exists: [%BaseDir%\Projects\RusLiveGena\Basic\Build\Macro_Library.script] evaluated string: [If,ExistFile,%API%,AddVariables,%API%,ApiVar,GLOBAL] AddVariables - Added section [ApiVar] from file [%BaseDir%\Projects\RusLiveGena\Basic\Build\Macro_Library.script] into the local variable list System - OnBuildExit [System,ONBUILDEXIT,Exec,%ProjectDir%\script.project,Gena-ONBUILDEXIT] [//If,Not,ExistFile,%RegSystem%,Run,%ProjectDir%\script.project,Process_DebugNT5x] SetVar - Sucessfuly changed the value of [%MultiBootDir%] to: [%BaseDir%\ISO\MultiBoot] IF - Directory does not exist: [%BaseDir%\ISO\MultiBoot] evaluated string: [If,NotExistDir,%MultiBootDir%,DirMake,%MultiBootDir%] DirMake - Created directory: [%BaseDir%\ISO\MultiBoot] IF - File does not exist: [%BaseDir%\ISO\MultiBoot\MultiBoot.ini] evaluated string: [If,Not,ExistFile,%MultiBootDir%\MultiBoot.ini,Begin] FileCreateBlank - Created a new file: [%BaseDir%\ISO\MultiBoot\MultiBoot.ini] IniWrite - Wrote INI key in file: [%BaseDir%\ISO\MultiBoot\MultiBoot.ini] Section [Config] Key [Count]: 0 IniWrite - Wrote INI key in file: [%BaseDir%\ISO\MultiBoot\MultiBoot.ini] Section [Config] Key [DefMenu]: 1 [End] IniRead - [%BaseDir%\ISO\MultiBoot\MultiBoot.ini] Section [Config] Key [Count] to variable: [%WimCount%] with value [0] StrFormat - converted: [inc,1] to variable: [%WimCount%] with result: [1] SetVar - Sucessfuly changed the value of [%NewSystemPath%] to: [i586] IF - [i586] is not equal to: [] evaluated string: [If,%NewSystemPath%,NotEqual,"",Begin] StrFormat - converted [UCASE(i586)] to variable: [%NewSystemPath%] with result: [I586] StrFormat - converted [Left(I586ZZZZ,4)] to variable: [%NewSystemPath%] with result: [I586] [End] IF - [i586] is not equal to: [] evaluated string: [If,%pTextBox4%,Equal,"",FileCopy,%WimBootTmp%\%pTextBox2%,%MultiBootDir%\%WimCount%.wim] ELSE - executing command: [FileCopy,%WimBootTmp%\%NewSystemPath%\%pTextBox2%,%MultiBootDir%\%WimCount%.wim] FileCopy - Failed to copy [%BaseDir%\ISO\HddBoot\I586\BootDI.wim] to: [%BaseDir%\ISO\MultiBoot\1.wim]: Системе не удается найти указанный путь. IniWrite - Wrote INI key in file: [%BaseDir%\ISO\MultiBoot\MultiBoot.ini] Section [wimboot] Key [1.wim]: 1.MM IniWrite - Wrote INI key in file: [%BaseDir%\ISO\MultiBoot\MultiBoot.ini] Section [Config] Key [Count]: 1 Finished processing script: WimBoot (WimBoot.script) Script time: 150 milliseconds Script has been sucessfully processed! You can post this log on the Reboot forums whenever you need help to properly debug the errors on this project More detailed documentation can be found on our wiki WinBuilder © 2006-2010 Nuno Brito |
