TAILORD
Silver Member | Редактировать | Профиль | Сообщение | Цитировать | Сообщить модератору Nik111 У меня нет, но у МС есть Цитата: You receive a 0x800f0922 or 0x80070005 error message when you try to install this update Symptoms Assume that you have either of the following configurations:•You have a Windows Server 2012 R2 server that is running on hardware that has UEFI that has Secure Boot enabled. •You have a Windows Server 2012 R2-based Hyper-V host that is running, and you are running a Generation 2 virtual machine guest that uses UEFI firmware support and that has the Secure Boot option enabled. Additionally, the guest virtual machine is running Windows Server 2012 R2. In these configurations, update 3000850 may not be installed, and you receive a 0x800f0922 or 0x80070005 error message. Solution To resolve this issue, follow these steps: 1.Install the updated servicing stack update 2975061, and then restart the computer. 2.Try to reinstall this update. | Короче установите KB2989647 (заменяет KB2975061) и перезагрузитесь. | Всего записей: 4294 | Зарегистр. 28-10-2005 | Отправлено: 14:48 22-11-2014 | Исправлено: TAILORD, 14:49 22-11-2014 |
