opt_step
Отчет об изменениях в списках
Смежные темы по Windоws 8/8.1
Обновления для других ОС
brduakhTMP
Microsoft Visual C++ 2015 (14.0.24212)
https://download.microsoft.com/download/6/D/F/6DF3FF94-F7F9-4F0B-838C-A328D1A7D0EE/vc_redist.x64.exe
https://download.microsoft.com/download/6/D/F/6DF3FF94-F7F9-4F0B-838C-A328D1A7D0EE/vc_redist.x86.exe
Microsoft Visual C++ 2013 (12.0.40660)
http://download.microsoft.com/download/C/D/2/CD274FA6-0D64-4B70-BD90-EC9A2E395DA4/vcredist_x64.exe
http://download.microsoft.com/download/C/D/2/CD274FA6-0D64-4B70-BD90-EC9A2E395DA4/vcredist_x86.exe
Microsoft Visual C++ 2012 (11.0.61030)
https://download.microsoft.com/download/E/C/C/ECCD0A46-78BF-4580-804C-CE0B61CF921E/VSU4/vcredist_x64.exe
https://download.microsoft.com/download/E/C/C/ECCD0A46-78BF-4580-804C-CE0B61CF921E/VSU4/vcredist_x86.exe
Microsoft Visual C++ 2010 (10.0.40219.325)
https://download.microsoft.com/download/1/6/5/165255E7-1014-4D0A-B094-B6A430A6BFFC/vcredist_x64.exe
https://download.microsoft.com/download/1/6/5/165255E7-1014-4D0A-B094-B6A430A6BFFC/vcredist_ia64.exe
https://download.microsoft.com/download/1/6/5/165255E7-1014-4D0A-B094-B6A430A6BFFC/vcredist_x86.exe
Microsoft Visual C++ 2008 (9.0.30729.5677)
https://download.microsoft.com/download/5/D/8/5D8C65CB-C849-4025-8E95-C3966CAFD8AE/vcredist_x64.exe
https://download.microsoft.com/download/5/D/8/5D8C65CB-C849-4025-8E95-C3966CAFD8AE/vcredist_IA64.exe
https://download.microsoft.com/download/5/D/8/5D8C65CB-C849-4025-8E95-C3966CAFD8AE/vcredist_x86.exe
Microsoft Visual C++ 2005 (8.0.50727.6195)
https://download.microsoft.com/download/8/B/4/8B42259F-5D70-43F4-AC2E-4B208FD8D66A/vcredist_x64.exe
https://download.microsoft.com/download/8/B/4/8B42259F-5D70-43F4-AC2E-4B208FD8D66A/vcredist_IA64.exe
https://download.microsoft.com/download/8/B/4/8B42259F-5D70-43F4-AC2E-4B208FD8D66A/vcredist_x86.exe
https://support.microsoft.com/ru-ru/kb/2977003
добавьте в шапку...
Всего записей: 6856 | Зарегистр. 20-04-2016 | Отправлено: 23:27 25-12-2016
DJ_Diablo
Спецы, выручайте, что только уже не делал над виндой 8.1, не ищет обновы, точнее идет бесконечный поиск...
Вот тут лог https://drive.google.com/open?id=0Bx50fw3tq5d_Um5uN1VSOGVJYnc
Всего записей: 2217 | Зарегистр. 09-08-2007 | Отправлено: 23:47 25-12-2016 | Исправлено: DJ_Diablo, 23:47 25-12-2016
ALEX90
DJ_Diablo
попробуйте _http://nnmclub.to/forum/viewtopic.php?t=880667
должно все наладиться
Всего записей: 4301 | Зарегистр. 20-01-2008 | Отправлено: 23:53 25-12-2016
bifido 76
DJ_Diablo
Пробуйте. Если при установке последнего обновления выдаст ошибку, то перезагрузитесь и заново запустите батник.
Всего записей: 2473 | Зарегистр. 08-04-2016 | Отправлено: 00:08 26-12-2016 | Исправлено: bifido 76, 00:08 26-12-2016
DJ_Diablo
bifido 76, спасибо! Ваш метод помог, теперь вижу процесс закачки обновлений)
Всего записей: 2217 | Зарегистр. 09-08-2007 | Отправлено: 01:02 26-12-2016
DJ_Diablo
Все установилось, кроме KB3184143
Выдает ошибку 800F0825.
Вручную тоже не ставиться.
PS: Воткнул через DISM этот апдейт!
Всего записей: 2217 | Зарегистр. 09-08-2007 | Отправлено: 10:49 26-12-2016 | Исправлено: DJ_Diablo, 15:36 26-12-2016
DJ_Diablo
del
Всего записей: 2217 | Зарегистр. 09-08-2007 | Отправлено: 14:21 26-12-2016 | Исправлено: DJ_Diablo, 15:36 26-12-2016
Tagg33
Всего записей: 79 | Зарегистр. 04-10-2015 | Отправлено: 15:29 26-12-2016 | Исправлено: Tagg33, 01:34 29-12-2016
ssassh
Разбираясь с проблемой последних обновлений, после некоторых манипуляций получил в статусе проверки целостности Repair-WindowsImage -Online -ScanHealth:
Path               :
Online             : False
Image Health State : Repairable
Restart Needed     : False
т.е. повреждение хранилища
На команду очистки базы: DISM /online /Cleanup-Image /StartComponentCleanup
выдаёт:
Ошибка: 14098
Хранилище компонентов повреждено.
При этом команды RestoreHealth выдают ошибку:
1)Dism /Online /Cleanup-Image /RestoreHealth
Ошибка: 3
Системе не удается найти указанный путь.
2)Dism /Online /Cleanup-Image /RestoreHealth /Source:F:\sources\install.wim:2 /LimitAccess
Ошибка: 0x800f081f
Не удалось найти исходные файлы.
При этом в CSB.log:
CBS    The alternate source path directory could not be accessed [HRESULT = 0x8007007b - ERROR_INVALID_NAME]
CBS    Failed to add new file source [HRESULT = 0x8007007b - ERROR_INVALID_NAME]
CBS    Failed to add alternate file source [HRESULT = 0x8007007b - ERROR_INVALID_NAME]
CBS    Failed adding alternate source directory [HRESULT = 0x8007007b - ERROR_INVALID_NAME]
CBS    Failed to Add Source using worker session [HRESULT = 0x8007007b]
Что довольно странно . Путь к смонтированному образу - верный.
Выход в интернет - тоже открыт.
Имеет ли значение какой свежести установочный образ должен быть указан для починки?
Если да, то подскажите как на базе древнего существующего образа Windows 8.1 Enterprise x64 и набора для автономной установки и интеграции обновлений Windows 8.1 по 13.12.2016 можно собрать свежий дистрибутив.
Или может какое более простое решение починки хранилища имеется?
Всего записей: 77 | Зарегистр. 29-06-2007 | Отправлено: 02:38 27-12-2016 | Исправлено: ssassh, 03:12 27-12-2016
CoolXazker
ssassh
Для начала набор нужно скачать и прочитать там инструкцию, можно в скрипт из набора внести изменения, можно из набора прогнать Пакетную установку MSU обновлений, нужное она доустановит, затем сделать очистку диска от имени администратора и повторить сканирование на целостность. Набор только для дистрибутивов Update 3
Всего записей: 1165 | Зарегистр. 06-09-2015 | Отправлено: 03:17 27-12-2016 | Исправлено: CoolXazker, 03:24 27-12-2016
bifido 76
ssassh
Если хотите, то могу попробовать посмотреть логи.
PS. У вас же до этого с результатами проверок все было в порядке (только одно обновление не ставилось), что за манипуляции привели к этому ?
Всего записей: 2473 | Зарегистр. 08-04-2016 | Отправлено: 03:20 27-12-2016 | Исправлено: bifido 76, 03:26 27-12-2016
CoolXazker
bifido 76
Давайте полностью логи
Угрожаете?
Всего записей: 1165 | Зарегистр. 06-09-2015 | Отправлено: 03:25 27-12-2016
bifido 76
CoolXazker
Каюсь , исправился.
Всего записей: 2473 | Зарегистр. 08-04-2016 | Отправлено: 03:27 27-12-2016
ssassh
bifido 76
Был бы очень благодарен.
Вот логи
Сделал для 2-х случаев:
1) Dism /Online /Cleanup-Image /RestoreHealth /Source:d:\WIN_MOD\install.wim:2 /LimitAccess
2) Dism /Online /Cleanup-Image /RestoreHealth
Не могу понять, почему в случае указания пути к образу он рычит
что за манипуляции привели к этому?
Я толком и сам не понял что именно, заметил это после того как не прошла команда:
P.S.: образ обновил по совету CoolXazker из последней подборке Win8.1Updates.
CoolXazker
Можно полюбопытствовать у Вас по инструкции обновления образа?
Для чего необходима следующая манипуляция с "Переместите обновление нужной разрядности kb3172729..." и почему это kb не требуется при автономной установке обновлений?
Всего записей: 77 | Зарегистр. 29-06-2007 | Отправлено: 20:11 27-12-2016 | Исправлено: ssassh, 20:20 27-12-2016
CoolXazker
ssassh
При пакетной установке программа его игнорирует как и kb3172614, приходится ставить их отдельно после рестарта, при интеграции никаких ограничений нет - все обновления интегрируются скопом, единственное нужно отдельное подключение dism для kb3172614, можете еще и NET 4.6.2 туда же попробовать добавить, ивлечь из него нужные cab файлы, как предложил bifido 76, пару страниц назад было в теме.
Изменил название сообщения в шапке - вы правы, многовато автономных установок для одного набора
Всего записей: 1165 | Зарегистр. 06-09-2015 | Отправлено: 20:39 27-12-2016 | Исправлено: CoolXazker, 20:47 27-12-2016
bifido 76
ssassh
Посмотрел логи - там очень много обновлений, которые вызывают ошибки. Имхо, проще поверх систему накатить, как до этого предлагал.
Всего записей: 2473 | Зарегистр. 08-04-2016 | Отправлено: 00:27 28-12-2016
ssassh
bifido 76
Это крайне нежелательный вариант для меня, к сожалению
Буду пытаться для начала всё же починить хранилище.
Из за чего вылазят при попытке обновления с локального репозитория следующие ошибки?
Всего записей: 77 | Зарегистр. 29-06-2007 | Отправлено: 00:41 28-12-2016
Tagg33
CoolXazker
Не понятно....с чем сравнить. что изменилось.
Всего записей: 79 | Зарегистр. 04-10-2015 | Отправлено: 02:42 28-12-2016
CoolXazker
Tagg33
Было для автономной, стало для пакетной
Всего записей: 1165 | Зарегистр. 06-09-2015 | Отправлено: 02:49 28-12-2016
bifido 76
ssassh
Еще раз более внимательно посмотрел лог. Лучше было бы сперва удалить старый лог, а затем выполнить только одну команду Dism /Online /Cleanup-Image /RestoreHealth, а так там получилась каша. В общем, насколько смог понять, есть проблема с пакетом от обновления KB3008923. Это обновление для IE11 (одно из самых ранних). Имхо, вероятно, проблема с хранилищем как-то связана с предыдущей проблемой - невозможностью установить последние обновления безопасности или накопительные. Чтобы понять как это устранить, было бы неплохо еще раз взглянуть на список пакетов в вашей системе -
dism /english /online /Get-Packages /format:table > "%USERPROFILE%\Desktop\Packages.txt"
Попробую сориентироваться по ним и сказать что вам нужно удалить или установить. Так же было бы хорошо знать использовали ли вы до этого при очистке параметр ResetBase.
Всего записей: 2473 | Зарегистр. 08-04-2016 | Отправлено: 07:29 28-12-2016 | Исправлено: bifido 76, 08:27 28-12-2016
