eGorZ
Gold Member | Редактировать | Профиль | Сообщение | ICQ | Цитировать | Сообщить модератору dirnola насчет ключей, привожу цитату Цитата: Setup Modes /passive Unattended Setup mode. No user interaction is required, but installation status is displayed. If a restart is required at the end of Setup, a dialog box will be presented to the user with a timer warning that the computer will restart in 30 seconds. /quiet Quiet mode. This is the same as unattended mode, but no status or error messages are displayed. | с кириллицей у тебя всё в порядке, вот только комментарии к апдейтам не длинноваты ли? Очень загромождается экран - один хрен их читать никто не будет - выводятся для отображения хода установки вместо ключа /passive, да и потом, если что либо будешь менять в cmd-файле - чтобы быстрее было искать. Остальные ключи: Цитата: Restart Options /norestart Does not restart when installation has completed /forcerestart Restarts the computer after installation and force other applications to close at shutdown without saving open files first. /warnrestart[:x] Presents a dialog box with a timer warning the user that the computer will restart in x seconds. (The default setting is 30 seconds.) Intended for use with the /quiet switch or the /passive switch. /promptrestart Display a dialog box prompting the local user to allow a restart Special Options /overwriteoem Overwrites OEM files without prompting /nobackup Does not back up files needed for uninstall /forceappsclose Forces other programs to close when the computer shuts down /log:path Allows the redirection of installation log files /integrate:path Integrates the update into the Windows source files. These files are located at the path that is specified in the switch. /extract[:path] Extracts files without starting the Setup program /ER Enables extended error reporting /verbose Enables verbose logging. During installation, creates %Windir%\CabBuild.log. This log details the files that are copied. Using this switch may cause the installation to proceed more slowly. | в последнем из апдейтов cmd-файла используй что-нить из раздела Restart Options, но только один из ключей, например вместо /norestart используй /warnrestart (без явного указания секунд ожидания у тебя 30 секунд до перезагрузки) или /promptrestart (предложит перезагрузиться и будет ожидать пожтверждения) или /forcerestart (просто перезагрузится никого не спрашивая). Цитата: если у этого хотфикса таковой в параметрах имеется а если нет? | запусти хотфикс с ключом /help или /? У меня в конце cmdlines.cmd устанавливается "European Fonts Update" - у него запрос на перезагрузку не отключить, поэтому я его в конец и поставил /overwriteoem - перезаписывает одноименные файлы ни у кого о том не спрашивая, если файл такой же, другого языка (это важно), или младшей версии. Цитата: А при запуске .cmd тож окошко DOS, как у батника? Если Dos, то индикатор разве увидишь? | если будешь использовать ключ /quiet - то будешь видеть только окно консоли с теми сообщениями что написал в Echo, если /passive - будешь видеть и окно консоли, и отображение хода установки в GUI окнах (считаю, что загромождать экран лишними окнами не стОит ) Цитата: 1. И последовательность, плиз, проверь. | мне проще выложить снова свои исправленные cmd-файлы с учетом последних наших совместных находок (ты многое добавил самостоятельно из того что я не устанавливаю на все машины). Основной принцип последовательности: сначала устанавливается само приложение, а затем хотфиксы и патчи к нему. Впрочем, если их расположить по мере выхода, то вреда не будет. Здесь последний вариант моих cmd-файлов - это всё работает. ЗЫ: лишние ключи /passive пока не убирал - всё равно они не мешают ввиду неиспользования Добавлено: TAILORD Цитата: Так неловко себя чувствую, да незачто ребята. Извините если я слишком рянно отстаивал свое мнение, просто я на практике не раз проверял свою правоту . | Это тебе спасибо за твою настойчивость На счет MSI Installer я настаивать не буду, но, из практики, я неоднократно в этом убеждался и продолжаю убеждаться каждый день - хоть он, как и всякое виндовое приложение "просит" перезагрузку после установки, но, если ты обращал внимание на сам процесс, то он, при установке, сначала останавливает все msi-сервисы старого инсталлера, а завершив установку, снова их запускает. Я неоднократно устанавливал под Win2000 ACDSee 7.0 - она написана под MSI 2.0. Запускаю установку программы - просит MSI Installer 2.0 и не ставится, устанавливаю MSI 2.0, затем, не перезагружаясь, тут же запускаю установку ACDSee 7.0 - всё проходит "на ура". Ну а мой cmdlines - тому подтверждение - многие хотфиксы и патчи (в особенности msi под .Net 2.0 и позднее) уже сделаны на MSI 3.0 - ставятся без проблем. Цитата: User Profile Hive Cleanup Service v1.6d А он тк уж обязателен? | если у тебя при выключении компьютера долго идет завершение сеанса, поставь эту штуку - результат использования будет очевиден. Цитата: Microsoft .NET Framework 1.1 Хоть и до сих пор предлагает его установить МС, судя по его же описаниям, им пользуются уж антикварные версии программ. Так что дело сугубо добровольное. Microsoft .NET Framework 2.0 Если уж так гнаться за модой, почему бы не Microsoft .NET Framework 3.0? Он и 2.0 и еще кое-что . К тому же и для него есть NET Framework Russian Language Pack. | Нет, дело не в моде - устанавливать надо все .Net - это так называемые run-time библиотеки для запуска приложений написанных с использованием этого языка программирования. Примеры тому: если прога написана на Visual FoxPro 7.0 или 8.0, то, несмотря на то, что у тебя будет в system32 лежать vfp9r.dll от 9-ой версии, она не запустится ни за что на свете. Тоже самое касается библиотек Visual C++, Visual Basic, Borland Delphi и т.д. Цитата: Windows Media Player 10 10? А чем 11 хуже? | на этот вопрос я отвечал ранее - WMP11 занчительно "тяжелее", а компьютеры бывают разные. Да и не всюду стоит Windows, который пройдет проверку на подлинность - ведь обновлять приходится разные системы Цитата: Может и не очень важно, но зачем писать такие длинные команды, чем эти короткие хуже? | на практике короткие команды не всегда отрабатывают - лучше использовать те, которые можно получить по ключам /help или /?, но самый лучший вариант открыть бюллетень безопасности в разделе Security Update Information и почитать рекомендации по установке там со всеми ключами в подтверждение этого запусти, например, WindowsXP-KB891781-x86-RUS.exe с ключом /?, и ты увидешь вместо /overwriteoem ключ /o , а вместо /nobackup ключ /n - это означает что длинные варианты этих ключей с этим хотфиксом работать не будут, но в то же время ключи /quiet, /passive и /norestart работают именно в таком написании. Хотя, могут быть и исключения Слишком много у M$ вариантов установщиков Добавлено: а вот из новинок от M$ - расширение Проводника по работе с фотографиями - пока только английский вариант Microsoft Photo Info 1.0 Overview Microsoft Photo Info allows photographers to add, change and delete common "metadata" properties for digital photographs from inside Windows Explorer. When installed, a new "Photo Info" item appears on the context menu for files selected in Windows Explorer. To use, simply select one or more image fiiles, right-click and choose "Photo Info" to open the Photo Info properties editor. You can edit metadata for files individually, or all together as a batch. Photo Info reads and writes metadata in IPTC and XMP formats (depending on file type). It also provides enhanced "hover tips" and additional sort properties for digital photographs in Windows Explorer. System Requirements Supported Operating Systems: Windows Vista; Windows XP Microsoft Photo Info requires 32-bit versions of Windows Vista or Windows XP with Service Pack 2 or later and the Microsoft .NET Framework 2.0 runtime installed. параметры для установки start /wait .\Applications\PhotoInfo\PhotoInfoSetup.msi /quiet /norestart | Всего записей: 6866 | Зарегистр. 21-10-2003 | Отправлено: 01:49 23-01-2007 | Исправлено: eGorZ, 03:12 23-01-2007 |
