evle
1 + int rand(100);
Часть 2 Часть 1
Поиск системы: В варезнике
levindd
скажитет а как сменить системный шрифт?
Всего записей: 23 | Зарегистр. 30-04-2008 | Отправлено: 11:54 08-08-2009
levindd
Панель управления\Оформление и персонализация\Персонализация\Цвет и внешний вид окна\Дополнительные параметры оформления
Всего записей: 20957 | Зарегистр. 27-12-2005 | Отправлено: 12:03 08-08-2009
levindd
levindd
спасибо ужо сам нашел!
Всего записей: 23 | Зарегистр. 30-04-2008 | Отправлено: 12:19 08-08-2009
Ksanderash
Насчет бага с chkdsk в Windows 7. Комментарий работника Майкрософт.
http://www.osnews.com/permalink?377377
Disclaimer: I work for Microsoft, and I work on NTFS.
Chkdsk intentionally uses lots of RAM to cache information in order to make the process complete as quickly as possible. The fact that this is using RAM is not, in itself, a problem.
The original report was of a bugcheck during this process. That really would be a problem. The original reporter upgraded drivers and no longer saw the bugcheck.
We have, in the last 30 or so hours, run chkdsk on hundreds of machines to see if we can find the cause of the crash. As of this writing, we have been unable to reproduce the crash condition; and since the original reporter can no longer generate the crash, we are left with one crash on one machine that no longer occurs. We have not been able to examine what caused any machine to crash in this process.
At this point, there's nothing to indicate that it's a bug users will frequently encounter, that it's a showstopper, or anything else.
There is a good chance that the original issue occurred presicely because the disk device was making mistakes (why does one run 'chkdsk /r'?)
A better blog post describing this bug can be found at http://blogs.zdnet.com/Bott/?p=1235 . See also Steven Sinofsky's response to the original reporter at http://www.chris123nt.com/2009/08/03/critical-bug-in-windows-7-rtm#comment-11469 .
If anyone out there is encountering crashes when running chkdsk, please let me know. I'll make sure it gets investigated promptly.
Since I'm a regular OSNews reader, when there is a nasty bug in the "NTFS driver stack", OSnews readers will be amongst the first to know. For better or worse (depending on your intentions) today is not that day.
Всего записей: 2141 | Зарегистр. 10-11-2005 | Отправлено: 12:26 08-08-2009 | Исправлено: Ksanderash, 12:28 08-08-2009
leha1987
Эт, конечно, хорошо, что они бага во время тестов не обнаружили,кроме как на одной машине, после обновления дров на которой стало всё ОК, значит на большинстве компов его не будет. Но странно то, что этот глюк судя по отзывам наблюдается не на одной машине. Хотя, может, и железо виновато, дрова на него или криво установленная винда, и т.д.
Всего записей: 102 | Зарегистр. 10-10-2006 | Отправлено: 12:36 08-08-2009 | Исправлено: leha1987, 12:38 08-08-2009
Ksanderash
leha1987
Стив Джобс?
Всего записей: 2141 | Зарегистр. 10-11-2005 | Отправлено: 12:41 08-08-2009 | Исправлено: Ksanderash, 12:43 08-08-2009
leha1987
Ksanderash
Стив Джобс?
это вы к чему ???
Всего записей: 102 | Зарегистр. 10-10-2006 | Отправлено: 12:48 08-08-2009
NPC
поставил 7600 ртм, а как исправить закрытие окон рывками? это же было и в RC
Всего записей: 8943 | Зарегистр. 17-02-2005 | Отправлено: 12:51 08-08-2009
leha1987
NPC
Дрова на видео последние стоят ???
Всего записей: 102 | Зарегистр. 10-10-2006 | Отправлено: 12:52 08-08-2009
NPC
leha1987 разные пробовал, карта нвидия 260 гтх, не помогает
Всего записей: 8943 | Зарегистр. 17-02-2005 | Отправлено: 12:55 08-08-2009
Ksanderash
leha1987
это вы к чему ???
Это я про двух людей )
Всего записей: 2141 | Зарегистр. 10-11-2005 | Отправлено: 12:58 08-08-2009
Lavik
NPC, Вы не один такой - нас целая "тема": "Проблемы с анимацией Aero"
Это такая "фишка".
Всего записей: 1478 | Зарегистр. 03-06-2004 | Отправлено: 13:12 08-08-2009
leha1987
Ksanderash
ну, я к сожалению, не Стив Джобс, и не веду от его имени блог, и не Билл Гейтс тем более
Я просто оставил своё личное мнение по поводу комментария Майкрософт.
P.S.: Кстати, довольно интересное итервью, только прочитал.
Всего записей: 102 | Зарегистр. 10-10-2006 | Отправлено: 13:12 08-08-2009
MaxPeacecity
"Она никак не видит.
Поймите, наконец, 32-битная архитектура не может видеть 4 гига.
Ну как дети малые. Вначале баловались с DirectX 10 под ХР; дошло до маразма - появляются уже DirectX 11, а на торрентс.ру и 12 (sis) под ХР.
Теперь пришло время помечтать о четырех гигах под 32-битной операционкой"
Вы частично ошибаетесь. Чтобы не распространяться долго и бессмысленно вам пример  - 32-битные СЕРВЕРНЫЕ варианты винды которые видят и используют столько оперативно сколько есть. Надеюсь тут никто не думает что раньше на всех серверах с вин было всего 3 гига оперативной?
Суть ограничения в том что 32битная не может произвести единовременную адресацию больше 3 гигабайт (вот как раз из-за упомянутого ограничения архитектуры). Если уж СОВСЕМ утрировать то она не может выделать ОДНОЙ программе больше 3 гигабайт, но может выделять по 3 каждой. (это не совсем верное высказывание но сильно упрощенное и приближенное чтобы понятно было).
В своё время видел патч (самопально-народный) подменяющий файлы отвечающие за работу памяти в ХР (32битной конечно) на таковые от вин сервер 2003 и соответственно позволяющие видеть (и использовать) хоть 4, хоть 8, хоть 16, хоть сколько вы там сможете засунуть в ваше десктоп (ограничение конечно есть - 64 гигабайта). Сам я его не пользовал тогда и работает ли такое нормально - не знаю. Но теоретически вполне возможно.
Толковая статья, правда подустаревшая тут (https://forum.antichat.net/printthread.php?t=96358). Как её продолжение можнт посмотреть тут http://www.ixbt.com/soft/windows-4gb.shtml А для владеющих языком вот тут http://www.tipandtrick.net/2008/how-to-enable-use-and-support-4gb-or-more-physical-ram-memory-in-32-bit-windows-vista/ пример где там чего меняли из файлов на примере виста 32 (там же показана как она видит 8 гигабайт памяти).
Но, читайте сами внимательно что можно сделать и нужно ли.
P.S. Линки - не реклама других ресурсов, просто копировать все оттуда сюда было бы извращением - слишком много.
P.P.S. Сам на x64 - всё равно будущее за ними.
Так по поводу моего вопроса о создания копии файла и шаблона  - что - никто ничего не знает и никаких идей? Или только вопросы вида какой фаерволл/антивирус работают в вин7 проходят?
Всего записей: 1146 | Зарегистр. 14-11-2007 | Отправлено: 13:15 08-08-2009
newsl
vadikanik
Обновлялся с Vista SP2 Rus, из проблем:
Пришлось удалить Daemon, Alcohol.
а можно ли обновиться с ВистаСП2рус на СевенИнглиш? и дадут тоже тока на рус?
Всего записей: 78 | Зарегистр. 06-06-2007 | Отправлено: 13:16 08-08-2009
1kot4u
1kot4u
С драйверами все в порядке? У меня нет проблем в VLC.
Ksanderash с дровами вроде все ок. на видео - (190.38), на звук и прочее с офф сайта.
Переустанавливал кодеки и влц с полной чисткой реестра - не помогает -(
Некоторые плееры нормально отображают картинку: WMP, winamp и MediaPlayerClassic? VLC к которому уже привык - ни в какую -(
Всего записей: 5 | Зарегистр. 31-05-2008 | Отправлено: 13:41 08-08-2009
NPC
Это такая "фишка".
Lavik ясно, спасибо за ссылку, впринципе это не напрягает
Всего записей: 8943 | Зарегистр. 17-02-2005 | Отправлено: 13:44 08-08-2009
Ksanderash
leha1987
Просто Apple называет себя в первую очередь софтверной компанией, отсюда их заинтересованность в ослаблении M$ как прямого конкурента-антипода. Похоже, ты не смотрел вот этот фильм, посмотри обязательно ) http://ru.wikipedia.org/wiki/Пираты_Силиконовой_долины_(фильм)
newsl
Нельзя. Это же в FAQ-е есть!
Всего записей: 2141 | Зарегистр. 10-11-2005 | Отправлено: 13:45 08-08-2009
Windrider
newsl
Обновиться можно только на тот же язык, т.е. если была русская система то и обновиться можно только на русскую.
Всего записей: 218 | Зарегистр. 28-01-2004 | Отправлено: 13:47 08-08-2009
Ksanderash
1kot4u
Очень странно. Никогда с VLC проблем не было. MPC тоже играет замечательно, если кодеки стоят. А VLC и на чистой системе, так как в него все интегрировано нужное.
Всего записей: 2141 | Зарегистр. 10-11-2005 | Отправлено: 13:48 08-08-2009
